SidecarFlip
Dec 12, 2017Explorer III
work2much wrote:
What type of batteries? In general sources of ignition are not advised in confined spaces with batteries but AGM could be ok, or sealing the batteries with venting as mentioned by sidecarfilp should be fine. The only other note would be that inverters can get hot and need space/venting as well.The only other note would be that inverters can get hot and need space/venting as well.
In my case, that space is quite large and the PSW unit has twin cooling fans plus the FW tank is in there, providing a bulk cooling effect. I've never heard the fans on the inverter run but they probably do. We run 2 CPAP machine on it every night and the coffee maker in the morning (unless I get up first and make percolator coffee).
