- How big? If 300 watts or less you can tap the main battery cable near the 12v fuse panel and wire direct into the 120v side with a transfer switch.
Yes if you have flooded batteries in a tight compartment I would avoid putting the inverter in there. - LwiddisNomadDon’t install any electrical device in a compartment with wet cell batteries...the gas they give off will corrode the device. Is your battery compartment well ventilated?
44,057 PostsLatest Activity: Mar 12, 2026
