Debbiepowers wrote:
Don't worry I am on my own unregulated land and the shower /sink will only be used with non toxic 100% organic soaps and run out to a gravel bed run off.
Sorry to rain on your parade, but most places do not allow dumping of gray water. If you're in Rhode Island, here is a document I found which states that Rhode Island does not allow it.
http://www.dem.ri.gov/pubs/regs/regs/water/isdsregs.pdf I don't believe it matters whether you own the land or not, or where it's located.
I'm not saying you won't get away with it, but if someone finds out about it, you could be in trouble. Is there a septic tank on the premises you could connect to? Or, if you could at least make it look like it's dumping into a cleanout with the dry well under the surface, it probably wouldn't draw any attention.
The other thing I'm curious about is that I've never heard of ANY motorized RV that was designed without tanks of any kind. Seems odd. If it was me and you were going to move the thing, I'd just install fresh, gray & black water tanks and plumb to them. Or is this a different RV than then one you mentioned in
this thread?
Good Luck,
~Rick
