TBammerExplorerJun 01, 2016Where to run solar panel wiringHas anyone installed solar panels on the roof of their TT? If so, how did you run the wiring? I don't see where I could run this through the walls, so it would have to be an exterior run. If so, any i...Show More
beemerphile1ExplorerJun 01, 2016or a tank vent stack. It will require drilling a hole in the stack inside and then sealing around the wire.
Related ContentFleetwood Angler wiringsolar pre-wired questions2005 SixPac D850 WiringBad tail light wiringAnother solar question.
