RCMAN46 wrote:
billyray50 wrote:
KD4UPL wrote:
billyray50 wrote:
KD4UPL wrote:
The '01 to '04.5 LB7 Duramax had injector problems. Otherwise they were good engines but I would avoid because of the expensive injectors. The '04.5 to '05 LLY Duramax was a fine engine, some report having over heating issues. This engine had the smallest fan of any Duramax. My '05 has 214,000 miles on it and doesn't overheat.
The '06 - '07.5 LBZ is considered the absolute best, basically flawless, highly sought after, usually expensive. The Allison transmission went from a 5 speed to a 6 speed in '06. Duramaxes from '07.5 and on were fine, no major problems, just gained emissions junk that hurts mileage and makes things complicated.
The statement that GM trucks carry less weight than the corresponding year Ford/Dodge trucks is simply not true. In '01 for example, a Dodge dually had a GVWR of 10,500 while GM was 11,400. The GM truck was also several hundred pounds lighter and thus had well over 1,000 pounds of additional payload.
I highly recommend a GM truck. I've had 4 of them and worked them hard in my business towing and hauling. I don't put up with machines that aren't reliable and work well. My GM trucks had extremely good track records. My current '05 dually has 214,000 miles on it. It carries my truck camper and family at about 1,700 pounds over it's GVWR. It rides and handles very well.
Not disagreeing with you but am curious. My neighbor at our seasonal sight just bought a 2016 Chevy LTZ DRW 4x2 Duramax/Allison and his GVWR and payload is a lot less on door jam stickers than my 2015 Ram Laramie longhorn CTD DRW and mine is a 4x4?
So what do the stickers say? I would guess teh Chevy has a GVWR of 13,000 and the Ram is 14,000. I would also guess that the Chevy weighs about 800 pounds less empty. That would mean it probably has a payload of 200 pounds less than the Ram.
I'm doing a lot of guessing.
Ok here is the sticker pics of my neighbors new 2016 Chevy Silverado LTZ 4x2 Duramax/Allison truck.
Not Chevy bashing here at all. Actually my neighbor is curious too. We both have same truck configuration except his is 4x2 and my Ram is 4x4.
OK where is the sticker for your Ram?
My Truck has a GVWR 14,000 and payload of 5565 LB
