billyray50
Apr 30, 2017Explorer
thedavidzoo wrote:
billyray, didn't you give up on the upper Stableloads before and get your money back? The install on newer Rams is a PITA, as we both have confirmed...
Yes I did. Then I ordered Supersway stops and for half the price. Permanently trimmed the Laramie longhorn custom wheel well liners to gain easy access to bump stops. The wheel well liners were the main culprit. However the ssa-2 models the bolt is to big in diameter for the Rams and would have had to drill bigger holes in bump stop frame. Did not want to do that. Return them too. Talked with Super Springs tech support and told me the SSA-2 should not be advertised to direct fit Rams. They are in process of developing SSa-3 direct fit for newer Rams now but not sure of Availability date so I will now try Torklift upper stable loads again.
44,068 PostsLatest Activity: Apr 17, 2021
