Nvr2loud
Nov 14, 2013Explorer II
BarneyS wrote:RCMAN46 wrote:
A septic tank is aerobic which is required for the bacteria to break things down. Your holding tank is not aerobic as it has a vent to the atmosphere. As such it will not break down the material thus it has to be flushed every couple days. I would not let anything stay in the tank for more than a week. Water is the holding tanks best friend.
There are both anaerobic and aerobic bacteria. The aerobic ones require oxygen and the anaerobic do not. I think you have your terms backwards in the post above. I also don't think it matters to the septic/holding tanks which kind they are. The bacteria will break down waste in either one if the material stays in the tank long enough and there is moisture present. Most RV holding tanks get emptied long before any decomposition can take place though, so just water is all that is usually required.
Barney
True, but most septic tanks are anaerobic and therefore the aerobic bacteria that enters the system die off.
44,066 PostsLatest Activity: May 18, 2026
