Perrysburg_Dodg
May 05, 2016Explorer
FishOnOne wrote:
But it also gets you the highest risk of contaminated DEF as well compared to a sealed container.
I've been running the API rated stuff in a container for almost 4 years and 92k miles without a single DEF issue.
Contaminated as in what? The pumps have filters on them (Flying-J and Pilot anyway). The only other thing I would worry about would be water in the holding tanks maybe. The DEF in an underground tank will be fresher than from a container. Heat is the what degrades DEF so unless the containers are in an area below 65* they will start to degrade.
Dirt would be the big thing as it will clog the injector not sure what effect rain or ground water would have on DEF. Also I have no idea what size holding tank they are running but the larger the tank the lower the effect.
Don
44,066 PostsLatest Activity: Apr 10, 2026
