minnow
May 14, 2016Explorer
Perrysburg Dodgeboy wrote:
Please do post some facts about "Again it's some dealer service departments(specifically RAM) making warranty denials based on "bad DEF" diagnosis that has some concerned." because I haven't seen any one posting this. Ford on the other hand has been doing it but I have not heard of Ram or GM doing it. At least not wide spreed anyway.
Don
For starters:
From Cumminsforum.com:
"My truck is back at the dealer with SCR problems once again.
Service guy just told me they have to replace the SCR filter and flush the DEF system due to me using other DEF fluid than MOPAR DEF fluid, they said I have to pay for the flush since is my fault for not using their DEF fluid.
Of course I told him to give me an official RAM writing that says that."
"Took to dealer on Saturday. Diagnosed as bad DEF leveling sensor. Apparently they had to replace the whole DEF pump. Didn't have it in stock...and was told on Tuesday that it is a back ordered part but they were able to find one at another dealer. Installed it this afternoon and I'm ready to roll.
"I asked them if they had seen this before. The service adviser said "it was probably bad DEF" and that next time I should stick with Mopar DEF! They said that bad DEF could void the warranty and that it's well over $1000 to replace the pump. I asked them to prove to me that it was bad DEF and I got a blank stare. They ended up taking care of me so no harm, no foul and it's fixed. But apparently DEF is not all good DEF per the dealer. Go figure."
"I have a 2013 base model for work and had the same problem. First trip to the dealer they told me their was nothing wrong, second trip they accused me of "dumping bugs and grass into my def tank to plug and wreck the def pump". They determined I needed a new pump, but it was on national back order and they didn't know when I could get one. I ended up calling the RAM helpline and got a little feedback. Still took about two weeks to get my pickup back and it wasn't covered under warranty. Truck has 15,000 miles."
From IRV2.com:
"10k miles on our RAM 1500 Ecodiesel and I have just had my 5 CEL (check. Engine light). 4 days ago the light came on with a message that it detected DEF fluid. I took it to a dealer who reported that there was a Dodge advisory on this issue, they did their magic and of i went (5 hours later). Yesterday the CEL pops up again (maybe 50 miles driven) this time the dealer claims that the DEF is bad??? (It conforms with the ISO requirement RAM published) and since it is a user problem it will cost me about $500.00 to drain,clean and replace the DEF. OUCH
Any Ecodiesel users here ever have a similar problem?
From dieseljeeps.com:
"DEF seems to be coming up quite a bit in the jeep forums. Unfortunately I have a problem with it too.
Story time:
My JGC has 17k miles on it. Recently I purchased 5 gallons of Peak blue DEF from auto zone and put it in the DEF tank. After about 5 miles of driving I got the message that I used the wrong fluid. Now how could I have put the wrong fluid in I thought...It is the same fluid that I have used all along Even when I had to fill the tank from empty when I bought the vehicle new.
So my trip to the dealership starts and my adventure begins:
The first thing they did was test the fluid. It came out at 35% with their tools which is high for the industry standard of 32%(+/- 1%). This apparently caused so much crystallization in the system that I had to have a new pump, injector, hose and a thorough DEF tank scrub all after less than 2 hrs of driving with the "bad fluid" in the tank. I was told that it was my fault for using bad fluid and that nothing would be covered under warranty.
So I contacted Peak Blue and asked for their batch testing results. They came back stating that the fluid is 2 weeks old and their fluid is at 31.3% and that there is no way that it could have gone up that high in that short amount of time.
Chrysler care was next, I provided the testing info and documentation supporting injectors going bad and catalytic converter problems as root cause from multiple sources even chrysler certified repair dealerships. Chrysler came back and said "the dealership has tested the fluid and you are still liable for repairs".
So $2900 later I have my jeep back. I am still in shock as to how this isnt covered especially since it is a known problem and many of you have had the same thing happen but it was a warranty repair.
So what to do now? I am at a loss and really need some support."
From ramforumz.com:
I have a 2015 ram cummins diesel usually used peak bluedef after 10,000 miles got a message in message center "improper def see dealer"took it to the dealer cost me $540.00 to have the def system totally drained and cleaned.
contacted peak to make a claim to see if I could recover some $ peak technical support said its a problem with the manufacturer not peak.
have any members had any similar problems?
the ram dealer said def has a 1 year shelf life and must NOT be stored in a hot or warm environment."
There's more but I think I made the point.
44,066 PostsLatest Activity: Apr 10, 2026
