HilltopMike's avatar
HilltopMike
Which company(s) still build quality TT?
So I've read through many pages here and am wondering:
What company(s) are currently building quality TTs?
If you could pick the top 5 or 10 who would they be? and why?
I'm sure this could be argumentative but I'm wondering is there a general consensus as to which manufacturers make a good product?
  • korbe wrote:
    I feel a lot of the "quality" will come from how a rig is maintained and also how it is used.
    The best thing a consumer can do is limit the exposure of the rig to rain and UV.
  • The biggest "fear" most TT owners have is water intrusion. Flat roofs, with openings for vents and A/C units, just are NOT the best design. Jayco went to their "Magnum Roof System" several years ago, not just to add strength and rigidity, but to shed water more quickly. It may not be perfect, but it is better than a flat roof.
    The second common area of water intrusion is at roof/side wall seam. Look at cargo/enclosed landscape trailers. Their roof wraps over the side in one piece and joins the side wall on the vertical. A piece of continuous Z-flashing at that joint would make it almost impermeable to water intrusion.
    The third area of water intrusion is at the windows. Some type of window water deflector, installed under the siding, or even Z-flashing would help prevent water leaks at windows.
    Stiffness against racking, side to side and front to back, is important, especially for long term durability. Heavier interior wallboard would help. Fully welded aluminum box tubing wall frames would help. A boxed frame and through frame welded transverse connectors/supports (look up images of F150 frame) really DO make a difference.
    The only manufacturer that I can think of that does any of these is Airstream (rounded side roof).
  • Every manufacturer has their good days and bad days. What matters more is the selling dealer and their service.
  • Your question comes through here every so often and each time I think about how many people here have actually owned over a hand full of rigs from different manufacturer's to make a valued analysis.
    For us, we feel or 2004 Crossroads Cruiser is quality made but we haven't been able to compare a bunch of other brands. Also, many people don't understand that 5ers and trailers are recreational vehicles, not built for every day use, IMHO.
44,029 PostsLatest Activity: Jan 28, 2025
