MikeRP
Mar 30, 2021Explorer
8.1 Van wrote:
All E rated tires of the same size should have the same weight capacity.Here is a 4,080 lb capacity tire :
Last year, I bought Cooper AT3 XLT 295/70R18 which is 4080 per tire. With that tire you get an extra 440 lbs per tire for a total of 880 lbs for the rear axle. That translates to an additional 4400 lbs you theoretically could haul on the fifth wheel at 20%. These numbers are for a 2018 Ram 3500 with 18 inch tires.
They are only 1 inch taller verified (my brother has the 275/70R18's) and they are wonderful tires. As soon as my new trucks Firestone HT's get some miles on them I'll replace them with these tires. $1700 for 5. But that gives you some serious extra capacity if you are close on the rear. I run about 6900 on the rear and I'm good for 7280. An extra 880 lbs gives some serious headroom. 60,000 mile warranty. You have to have them force balanced. I may put on centrimatic balancers right away.
