3oaks wrote:
SoundGuy wrote:
camp-n-family wrote:
Since you have a 600/6000 already, try it first. No point spending money if you don't need it. You're well within your trucks' limits by the sounds of it so you're not going to hurt anything. After trying it you can always just upgrade the bars if you find the ride too soft or are having difficulty transferring enough weight.
Not with an Equal-i-zer you can't, he'll need a new head as well so it would be better to just sell the 600 and buy a complete new 1000 ... if he had a Blue Ox Sway Pro he could upgrade by just changing the spring bars.
Yep, been there, done that, with Equal-i-zer hitches when we went from a pop-up to a much heavier TT.
The Blue Ox Sway Pro wasn't in the equation back then. Although I am quite happy with my Equal-i-zer hitch. Just that I had to purchase the second entire hitch assembly.
I stand corrected. Didn't realize the hitch head was different weight rated as well and the bars aren't interchangeable. Either way, try what you have first before spending money that you may not need to. You'll be at the limit of the hitch but the truck will handle it fine. The heavier bars would be more important if the truck was near the limits.
