Huntindog wrote:
BTW.... I have used the EQUALIZER for about 15 years... Am now on my third one, due to needing different sizes.
As have I towed many tens of thousands of miles with an Equal-i-zer. ;) By definition, in order for
anything to flex it needs to bend and those Equal-i-zer spring bars which are made of solid square steel stock, 1" in the case of a 1000 / 10,000 lb version, have very little ability to bend. No bend = no flex. :W
Had you chosen a Blue Ox Sway Pro instead you'd have that flex you seem so desperate to achieve as
those spring bars are
designed to flex AND when you changed from one trailer to another you wouldn't have had to buy an entirely new system as you have with the Equal-i-zer. :R
Enjoy your Equal-i-zer - as effective but outdated design as it may now be. :p
