DutchmenSport's avatar
Sep 25, 2013
Which generator do you recommend?
I have a King Kraft generator that has (and still is) running very well with absolutely no issues. It came when I purchased my Keystone Springdale TT around 2006 or so. I've not used it with the camper very much, but it has come in very handy around the house for winter and extremely stormy days at home when the power goes out.
I did try it with the Springdale and it ran the air conditioner successfully, but like I said, never really had a need to use it camping as we've always had electric hook-ups.
Fast forward.
About a month ago we traded the Springdale for our new Outback. So, like we all do, I'm still experimenting with "this and that" and tonight I tried the generator. I also now have a surge protector for the camper that reads the volts and amp load and will kick off with high or low voltage.
The situation has come up where I'd like to be able to set-up using the generator, but the generator spits out 16 amps and the camper load with the air on is around 19. The surge protector shut the trailer down. So, I don't think the generator is adequate for our need (good for the house to keep the freezer running and our satellite TV operational and blower in our fireplace though).
We've decided we're going to get another generator we can satisfactorily use with the Outback, but need something that will spit out at least 20 amps, and more is better. But we also don't want something so gigantic it's impossible to move. We'd like it to run quiet, but most important is the output.
So my question? Does such a generator exist that won't break the financial camel's back? We'll have all winter to save our pennies and (most likely) in April 2014 will purchase a new one (my birthday).
I would kindly appreciate your recommendations (starting points) I can further research.
  • does you AC have a quick start kit. if not, check out a duo-therm part number. 3102901.006 for ideas.
    bumpy
    Get 2- 2k units. What's your budget?
    That is what I would do but I already have one Honda Companion.
  • We bought a champion 3500/4000w startup watts and have used it for two seasons. It's not as quiet as the Hondas but we use it at races so it's no big deal. A/C runs great and as long as I don't turn on microwave at the same time we're good. The best $300 I ever spent, plus $50 for the wheel kit. It takes two to get it out of the back of the truck but it's not that bad (my wife can help get it out of the truck with me)
  • I don't know, I like the Powerhouse PH3100Ri that I'm using. Just picked up my second one, under $1400 out the door at Camping World. That is with a factory 2 year parts and labor warranty and a Camping World (or Good Sam) extended 2 year parts and labor warranty. So that's 4 years free parts and labor.
  • There must be something else on besides the air. Low batteries? Water heater? Fridge?
  • I have a Honda 6500 and a Yamaha 3000. Both will do a great job of running your TT.
  • If you can afford it then get two Honda 2000 or Yamaha 2000s. They are worth the money spent if you use them frequently. If you're on a budget then get the Champion 3500/4000. The Champion is around $350.00 while the Honda/Yamahas will come in over $2000.00. The Champion is louder and not an "inverter" model but from what I have researched and from other users posts they are a fine product.
  • Do the math. Watts divided by 120V = amps. So, if you need at least 20 amp output you would need at least a 2400 watt generator. In reality that means you need a 3000 watt generator to meet your most basic needs. Most A/C units will do OK with 15 amps but you know your unit better than anyone.
