HydrogenCyanide's avatar
Oct 14, 2020
Which Shocks for 2017 F150 Ecoboost
I've had the tow vehicle since new. Approaching 60,000 miles with roughly 20% of them towing.
My first travel trailer with this truck was a Keystone Cougar28RBS. MY wife got 2 footidice and we upgraded to a Sporttrek Touring 312VBH. A little longer and a little heavier.
This trailer has given me some towing problems. I've since re-adjusted the equalizer hitch and I think I have it setup correctly now. I still can feel the increase in weight even though it is only 150pounds heavier and hitch weight of 1200 vs 1050 of the old trailer.
To be clear, when I say problems, nothing to do with power. I just feel it is a little bouncier and at time feel the trailer is pushing the truck around a bit when it gets bouncing.
Will upgraded shocks help? I assume that they cannot hurt. Any recommendations on which shocks to buy.
Also....I have looked the 3/4 tonne route, but financially it just does not make sense at this time. In the end, if I can't make this work, I'll upgrade, but I'd like to see if something small like shocks will improve things first.
Interested in opinions on this.
Thanks
  • Could be shocks, I would try first.
    Another, is if you have P metric tires, or the HT ones, Its also possible those are too soft for the heavier hitch weight of the new trailer. So a set of LT C or D tires would help this too.
    Not that i would swag this, but the rear springs may be worn. I doubt it personally. Going to a heavier version, ie instead of say 3000 lb springs, go with 3500 or 4000 lb rated springs. Fords are known for having lighter springs than one thinks they should GM had 3900 lbs for all 15 series versions. Ford has multiple from 3000 up to 4500 or there about.
    ANy of these fixes are cheap compared to a new 25 series truck.
    Marty
  • Trying new shocks is an inexpensive option IMO. No reason that engine power would be a factor.
