carringb
May 12, 2019Explorer
hvac wrote:
This is great feedback. It's intriguing as its basically a 1 ton truck, so payload will not be an issue. Some other comments on the net is the hitch itself from Nissan is the limiting factor for a higher tow rating.
I think it's more likely Nissan spec'd a hitch to meet the GCWR. With OE tow package GCWR = 16,000 lbs without OE tow package GCWR = 13,500 lbs.
16,000 GCWR is the same as the Chevy/GMC with the 6.0L.
Ford E350's with the V10 were rated for 18,500 combined with 4.10 gears. I swapped in E450 axles under mine with 4.56 gears, rated at 22,000 combined. 2014 was the last year of the E350 wagons and vans.
Note: The Transit is the only van certified under ASE J2807, so comparing the Express/NV/E-series to the Transit tow rating isn't exactly apples to apples. Maybe more like apples to pears. Also some variants of the new 2020 version are getting an increased GCWR.
44,067 PostsLatest Activity: Jun 05, 2026
