el_jefe1's avatar
el_jefe1
Which van has largest tow capacity
I was doing a little research online today to try to start looking at what our next van should be. Mind you, I'm only starting to look, which means I'm a couple years away from actually doing anything:). But I want to know what my options are. When I bought our van in didn't really consider towing, but it seems like I'm driving the most capable towing van out there. Unless somebody knows of something better?
I'm in a 2007 Chevy Express 3500, it's rated for 10,000 lbs towing, I believe 16000 gvwr. Which we hit the scales at just over 15,000, so all good there. But I don't know of any vans with a higher payload than that. Anyone know of any?
I'm not opposed to just getting a newer version of what we already have, but just wondering if anyone knows of other options to check out.
Oh I should mention we have 10 kids. So it needs to be a pretty big van:)
  • The Transit is unibody construction, no beefy chassis like the E series.
    I am very happy with my Transit, but my trailer is also quite light.
  • el.jefe wrote:
    I looked at the Transit first because that seems to be the new popular van for families our size, but it doesn't look like they can tow worth anything. Our trailer is about 8500 lbs fully loaded, so I need something with some muscle.
    The Transit has plenty of muscle and in a tow test like the Ike Gauntlet would probably perform comparably with the Express. The issue is the 13,000 lb GCWR which seems low. I imagine it has something to do with cooling and the Transit is considered a commercial vehicle which requires a tougher duty cycle.
  • I looked at the Transit first because that seems to be the new popular van for families our size, but it doesn't look like they can tow worth anything. Our trailer is about 8500 lbs fully loaded, so I need something with some muscle.
  • fitznj wrote:
    I was in the same boat earlier this year;
    I had a 2008 Chevy Express 3500 towing a 27ft - 5,500 lb trailer; It was
    great - tons of torque and comfortable to drive.
    I was thinking of buying another with the 6-speed transmission and really could not fault the Chevy. But I thought let me take a look at "new" technology even
    though 1-2 year old Chevy was about $2000 cheaper than a Transit/Nissan.
    I test drove a couple of Transit and was impressed, so I started looking
    around for a 350XLT EcoBoost (passenger) - which I eventually bought.
    So how do the 2 compare?
    The Transit is 18 longer wheelbase and tows MUCH better than the Chevy; The
    Ecoboost has tons of torque and comes on at lower revs and just seems to
    pull. It's coupled to a great 6-speed transmission which is totally seamless
    and has an easy to use rocker switch to hold/change gears;
    The Transit is much quieter - very little engine noise intrusion and better
    wind noise management. Ergonomics are better and feel more modern. The brakes
    are also superior.
    Fuel economy is MUCH better;
    Unloaded - 14mpg -> 20mpg
    Towing - 11mpg -> 14mpg
    The downside:
    - Max towing is limited to 7,000? lbs (but I don't think the Chevy can
    "comfortably" tow much more );
    - The driving position is "bus like" which takes getting used to.
    Hope this helps.
    Very interesting report on the new Transit. I note that it is the 350 version. I don't know very much about these new Ford vans...do you have the dual rear wheels or single rear wheel set up ?
    That MPG is quite good...is that the EcoBoost 3.5 liter turbo V6 engine ?
  • My 2006 E350 V10 is rated at 10,000lbs towing with the V10/4.10 gearing and GCWR is 18,500. I have the 12 passenger model. You will be hard pressed to find anything "new" as capable compared to what you/we already have. I looked at the Nissan and love the ability to configure the seating in so many ways. i think i read there's a diesel version in the works so towing capabilities may get better.
  • I was in the same boat earlier this year;
    are also superior.
    The downside:
    Hope this helps.
  • If you're happy with your van, I'd stick with a newer version of the same. IIRC it's the only van on the market that can seat 12 with a GCWR that works for you. I think the Nissan NV 3500 can seat 12 but I don't know if the GCWR is sufficient for you.
