- Grit_dogNavigator III
06Fargo wrote:
Equipped the 1 ton with rear air suspension, pyrometer, manifold pressure gauges, mild tow tuner... it still needs better brakes, parking brake (it's manual trans), slower reverse in 2wd (2wd low switch kit not available for this model)
Next big mod will be the KW mod: Clicky
^That is pure awesomeness! - BB_TXNomadTruck has plenty of power. Not going to do anything that might impact warranty on that expensive engine.
- Triker33ExplorerToad Dyno 355HP 380 ft lb
160 Hi Performance thermostat, Catted down pipes, 3-Bar Map and Tuner for Stock/91 Octane/93 Octane, Airaid air cleaner and Dynomax muffler - 4x4ordExplorer IIIMud flaps, B&W hitch and weather tech floor mats
- Chuck_thehammerExplorerCorvette is done, 500 hp from a 383 cubic inch, a 1979.
motorcycle ... 120 hp from 110 cubic inch and 700 pounds.
Truck, nothing to the engine.. truck/motorcycle/30 foot travel trailer is 17,000 pounds rolling.. need dependability.
44,056 PostsLatest Activity: May 04, 2014
