After doing an oil change? Do ya dump in the reccomended amount of oil, put the cap on, slam the hood down and takeoff? Or do you check to make sure it reads right on the dipschtick?
I always check it following an oil change and then again after it has been driven for a day or so. Also checking for leaks as well. A minute of time is worth it if I find something amiss with the oil level.
