Grit_dog
Dec 18, 2018Navigator III
Who checks their oil?
After doing an oil change? Do ya dump in the reccomended amount of oil, put the cap on, slam the hood down and takeoff? Or do you check to make sure it reads right on the dipschtick?
Me Again wrote:Super_Dave wrote:
I get my oil changed at Jiffy Lube and check it before I leave the store. My truck has an capacity oil pan so I want to make sure they don't just put in the recommended amount.
You are very brave. Do you ask to see the filter and assure the gasket is still on the old filter. I had someone else once change my oil and asked if he had check for the old gasket. He said yep. I said show me the filer and there is was WITHOUT a gasket. They did not charge me!!! Chris
