- 3_dog_nightsExplorerI don't doubt he can pull it, I worry about them stopping it.
- kellertx5erExplorer
GordonThree wrote:
Good for him / them... not everybody has $50-70k for a nicely equipped 3/4 or 1 ton.
Hopefully they had enough $$$ to properly install the hitch, and a brake controller. - BumpyroadExplorerlooks to me like he better not make a sharp turn??
bumpy - GordonThreeExplorerGood for him / them... not everybody has $50-70k for a nicely equipped 3/4 or 1 ton.
- msgtordExplorerI would think you would have to build a sub frame to attach the 5th wheel hitch to.
- Me_AgainExplorer III
dodge guy wrote:
Those are just drilled through he floor and bolted to the frame!
What frame? Unibody!!! Chris - dodge_guyExplorer IIIt's built on a minivan/crossover body. The material under the bed floor is metal. I'm sure it's attached the same way they do regular pick ups. Those are just drilled through he floor and bolted to the frame!
- rhagfoExplorer III
carringb wrote:
What the heck did he attach the hitch to? Isn't the bed floor a plastic composite?
Can be even turn?
Not sure about the material, but there is a "Trunk" under the bed, wonder what he did with it.
Likely didn't have an issue with the weight 5,000# towing capacity. - carringbExplorerWhat the heck did he attach the hitch to? Isn't the bed floor a plastic composite?
Can be even turn? - RoyBExplorer IILots of photos on GOOGLE IMAGES on-line showing small vehicles towing 5th wheel trailers...
The problem comes when going down US82 between MS and Arkansas and meeting one of those hugh truck loads of logs stacked up 12-feet tall going 70MPG on a two lane road... Your chances are not good haha...
I used to spot my 4200lb popup trailer at home here all the time with my Sears LT1000 yard tractor too... Looked something like this google image photo
"Where there is will there is usually a way..."
Roy Ken
44,056 PostsLatest Activity: May 04, 2014
