solismaris's avatar
solismaris
Why 4.1 axle?
I tow an 8000 pound trailer with a GMC 2500 with 6.0l engine, 4 speed transmission, and 4.1 axle ratio. I rarely need 3rd gear on the highway; only on steep hills.
For my next truck, why not get similar engine but a 3.7 ratio? (For better economy when I'm not towing.) My reasoning is I can just use a lower gear if necessary. With the new 6-speed transmissions now common there should be plenty of gears to chose from. If that would work, why suffer the lower economy of the 4.1 ratio when I'm not towing?
  • Your reasoning is sound. The GCWR of the proposed truck with various axle ratios will give you explicit info on the capabilities.
