BFL13
Jun 26, 2019Explorer II
myredracer wrote:
Just got a "new" 2012 GMC Sierra 2500 CC. Just ran through a hwy truck scale today. The door jamb sticker says payload capacity of 2922 lbs but when I subtract the actual weight from the GVWR, I get 1674 lbs. Just added a canopy/cap and am guessing it weighs around 200 lbs so that would account for a bit of the difference.
Same thing on our old F250. It had a sticker payload cap. of 2800 lbs (approx., going by memory) and an actual of 1800 (again,approx. by memory).
Is it because the vehicle manufacturers use a stripped out reg. cab model for GVWR? The crew cab and 4x4 driveline stuff will add quite a bit of wt. Maybe that's the answer??
Our TT has a TW of 950 lbs. So the Sierra is okay there, but what if we had 4 adults, the dog and a bunch of cr@p in the bed? We'd be over the GVWR...
Your weights look about right for that truck.
The 9500 GVWR is the same for all versions of that truck. BUT different versions weigh more than others. So what they can carry varies.
A Diesel with the heavier transmission weighs about 1,100 lbs more than the gas engine with the lighter transmission, and 4x4 adds about 400 lbs to the truck's weight. CC, long box, all adds weight. That all comes off the 9500.
That is why a Diesel 4x4 2500HD has hardly any cargo capacity compared with a gasser 2 WD, and why you get all this trouble with them trying to tow a 5er, where the pin weight can put them way over their ratings.
"Payload" is not a good word to use with GM trucks. They have "cargo capacity" (for in the box) and passenger weight to add up. In the 2003s they allowed 150 lbs per person in the cab, so a five seater would be 750 lbs for that. A full tank of gas was assumed, so you don't count that. Check in the glove box for your cargo weight rating and add 150 lbs per seat for what you are "allowed" to hit the GVWR.
You can use some of the passenger allowance as "cargo" in the box, but IMO there is something not quite right about that, since they make a fuss about centre of gravity location for a slide-in camper as the cargo in the box, and all that. The truck doesn't seem to care :) .
For comparison with a 2003 2500HD ext cab long box 2WD gasser, at 9200 GVWR, it weighs about 6,000 lbs empty, has 5 seats (750 lbs) and cargo 2,750 (for in the box) so "payload" is about 3,500.
Same truck with Diesel and 4x4 would be 1,100 + 400 less capacity, so "payload" would be 2,000 and take 750 off that for what can go in the box-- 1,250 lbs! Not much there for pin weight and a hitch .
So the OP's truck seems about right.
You have to pick the right truck for the job between what it can pull and what it can carry. Diesels can pull more but can't carry as much.
There are also ratings for the front, in case of snow plowing, and for the rear. Adding them puts you over the GVWR. Once over the GVWR you have to decide what to do. "Weight police" will say do something, and the other guys will say ratings are BS, so just carry on. GM does not tell you what the "margin" is that you can go over before something breaks. So you are on your own for that.
44,070 PostsLatest Activity: Jul 01, 2022
