richy2's avatar
richy2
Explorer II
Oct 14, 2015
Why all manufacturers do not use composite?
Since purchasing a Evergreen Everlite trailer new in 2010, I have wondered why all builders of rv's do not use composite materials rather than wood in their construction. I have had no worries or issues with leaks with this trailer, however, all four of my previous trailers developed leaks. Most of the time damage was done before leak became apparent. I maintain my rigs by the book,so lack of maintenance is not the issue. We have reached the point where we would like a different floor plan with certain length and weight specs other than the ones available at Evergreen. We will not consider any brand that uses wood, so we will wait and see what develops.
There are many posts on this site concerning wood rot and repairs due to water damage. It may cost a little more to build with composite, but I think customer satisfaction would be greatly improved. Just my thoughts.
Apparently I need to clarify the word composite as it relates to rv construction. A composite panel is usually an aluminum frame with block insulation sandwiched with two sheets of a plastic like material that is not subject to degradation due to water or mold. Azdel is commonly used in this process. These components are bonded together ideally with vacuum. A roof or floor panel is about 4" ,wall panels 1/1/2 to 2". NO WOOD.
  • What do you mean by composite? In my definition, composite means something comprised of two or more materials. For instance, a wood floor with a bonded epoxy overlay is a composite. A plywood countertop with bonded formica top is a composite. Fiberglass is a composite (glass fiber reinforced plastic).
