ShinerBock
Oct 20, 2020Explorer
On the right is the BSFC of the new 2019 standard output Cummins with a higher compression ratio. Its sweet spot is much larger than the 2018 and it would be even more advantageous to tow in 5th at more speeds and loads than 6th if you had a 3.42 axle.
