ShinerBock
Oct 25, 2020Explorer
FishOnOne wrote:SweetLou wrote:Cummins12V98 wrote:
"When towing, whatever gear keeps engine rpm between 1,800 and 2,000 rpm will give the best fuel mileage and power because that is the rpm window where the Cummins 6.7-liter makes peak torque.
I tow at 60 with rpm's about 1,750. Just right! That's with 4.10's. At 70 I am about 2,000.
With my last DRW I had 3.42's. I would tow in 5th at same rpm's as above, just right!
Exactly right
Exactly wrong.
The 6.7 cummins only makes it's peak torque at wide open throttle and full boost at that rpm and I'm pretty sure no one drives down the highway at wide open throttel.
Fish, I believe you are misunderstanding what is being said here. Generally, engines are more efficient under load around the rpm that they make peak torque. This is actually true for most engines. They are not saying to drive around at WOT.
