mileshuff
Jul 31, 2021Explorer
theoldwizard1 wrote:
From what I can find online, the standard tire size for your truck is 265/75R16. The standard Defender weight rating is is 2756 lbs/tire. There is an LT265R16 (load range E - 10 ply rating) version that is 3415 lbs/tire.
They also make a LT285/75R16 version that is 3750 lbs/tire. After multiple blowouts I would want these !
Inflate to the pressure recommended by the TIRE MANUFACTURER !
All tires have been factory size at LT265/70R17. All have been E rated 10 ply. Current LTX M/S are rated at 3195 lb at 80 PSI. Very similar to the other tires I've had.
