Cummins12V98
Jul 31, 2021Explorer III
theoldwizard1 wrote:mileshuff wrote:
All tires have been factory size at LT265/70R17. All have been E rated 10 ply. Current LTX M/S are rated at 3195 lb at 80 PSI. Very similar to the other tires I've had.
You still need to verify the weight on the rear axle !
Seems odd, but you may have to shift to 16" rims and LT 285/75R16 tires which have a higher payload.
What does the door sticker say for tire pressure ? If you are filling them to 80 psi cold, they will be running more than that hot !
Uh I think that’s how you are supposed to fill them.
