pitch
Aug 01, 2021Explorer II
Have all the blowout been on the same rim? I don't think over inflation would be the problem as e rated tires are generally good for 80#
Before you mount your new ones have the rim checked for trueness.
Long shot but make sure your axle is also running true. Three flats in the same position is just not normal. I think you are looking at some mechanical fault.
