Grit_dog
Aug 01, 2021Trailblazer
dodge guy wrote:
I’ll second the only rotate front to back. That’s all I do. Going side to side can cause damage because the tire has a memory and when it spins in one direction for thousands of miles and you switch it to rotate in a different direction then it came cause the rubber and steel to fatigue sooner. Bias plus never had that issue.
That is the biggest falsehood I’ve heard posted on here in a while! Which says alot considering this is rvnet, the land of wacky theories and methodologies! Lol
I find it hard to believe you even said that. Aren’t you a Dodge mechanic? You should know better.
