Grit_dog
Aug 02, 2021Trailblazer
dodge guy wrote:
And yes changing the direction of rotation of a tire after thousands of miles can and does make a difference!
That you are correct sir. It DOES make a difference, for the good though, by correcting the tread feathering rather than allowing it to continue, if direction of rotation is changed by swapping L to R on the same axle. (Speaking for rwd/4wd vehicles, never had a fwd car long enough to care aboot the tires_
X rotation also changes rotation, but does not correct tread feathering.
If one watches how a tire wears in a specific position on a vehicle, there is almost always an option (not always the same option) to optimize the life of all 4 tires.
General exceptions being tires worn quicker or unevenly due to vehicle issues (alignment, etc), or lack of rotations causing a pair to wear further than the other , or burnouts! lol
But the notion that changing rotational direction on a tire that is not a directional tire is somehow harming the tire inherently is absolutely false.
FWIW, even directional tires will not be damaged running "backwards", they just won't perform quite as well.
But I am not the authority on tires....nor are you, or you'd understand this.
PS, you should tell capriracer he's FOS too, but I believe he actually is "the guy."
