towpro
Sep 18, 2020Explorer
Why do I need a DC to DC charger?
I came to this group because of the tendency for truck campers to be more off grid oriented with knowledge about coach batteries.
Unless your using Lithium, why would you need a DC to DC charger between truck and coach? I know there will be some loss in the factory wiring (which gets smaller every year) but do I really need to limit current or voltage?
On my Ram it was not switched, and I knew to unplug the cord when camping to not discharge the truck batteries. Is the DC to DC charger only to prevent the truck battery discharge?
I was tempted to put a bluesea ACR on this line but they will conduct either direct either directions at a given voltage, IE my Camper solar would start to charge truck batteries which I don't need.
Really this question comes from I am wiring a new Toad. My Jeep Liberty I have the 12V feed wire from RV connected (fused) direct to the battery. Now I am wiring a new toad, a Ford C-max and I am reading about everyone using these special DC to DC chargers. But why do I need it? The truck alternator is only going to put out a max voltage, by the time it goes through the thin wire to the toad, its going to be even lower, so why do I need to regulated it?
