RbertalottoExplorerJul 27, 2013Why does my water pump cycle every20 minutes??1998 Palomino Bronco............ Hot Water heater is turned off, but is open to the water supply. No leaks anywhere, no water escaping......Camper has no Grey Water tank. Surflo pump cycles f...Show More
Mick9064ExplorerJul 28, 2013I had that problem and it turned out to be an air leak in the winterization valve where you put the antifreeze in.Mick
