- KD4UPLExplorer IINot normal.
I had that problem. I replaced the check valve in the pump and it solved it.
The water was leaking back into the unpressurized tank. It doesn't hurt anything but it is annoying. - BumpyroadExplorera very small leak from city water to the fresh water tank will do this. my bounder had an in line valve and Its O ring had a microscopic groove on it allowing an eventual leakage of water/pressure and would do the same thing.
bumpy - _DJ_1Explorer IIIf no leaks then I agree with faulty pump. There is a check valve in the pump that keeps the pressure that is probably bad. Hurts nothing, just annoying.
My TT has been doing it all summer. We just turn it off between uses. - nycsteveExplorerDont think its normal. Water heater full? If theres any air in the heater that could cause the pump to cycle.
My guess, either a faulty pump or an undiscovered leak.
44,043 PostsLatest Activity: Jul 24, 2025
