Huntindog
Oct 31, 2017Explorer
profdant139 wrote:
Well, I followed up on Huntingdog's suggestion, and I am surprised:
One model of Airstream, the Classic, uses LT tires. Almost all of the rest of their models are ST. This info is on the "Features" link for each model. The other exception is the little Basecamp, which uses 18 inch (!!) Goodyear Assurance tires. Not sure if those are LT or passenger tires, but they are not ST.
All Arctic Fox models, both trailers and 5th wheels, use ST. See this link and scroll down to the end:
Arctic Fox Brochure
The biggest Lance trailer I could find, the 2375, uses ST tires.
So this tells me something: first, the fact that Airstream uses LT tires on its biggest model means that LT tires are not unsuitable for towing. Airstream would not steer its customers wrong on a $140,000 trailer.
Second, the fact that almost all of the other high end models by Airstream, Arctic Fox, and Lance (three of the best manufacturers) use ST as standard equipment means that these luxury-market firms are happy with ST, which means that ST is probably not just a low-cost alternative.
Frankly, I expected to see LT tires on some of the big Arctic Fox units. They are known for building rugged trailers that go off-pavement.
So, based on the behavior of the trailer manufacturers (rather than the tire manufacturers, who are just responding to the trailer makers), I conclude that ST tires must be ok for most applications, especially smaller single axle trailers. But the fact that Airstream uses LT on its biggest unit means that LT tires are also ok, at least on large dual axle trailer. The caveat, of course, is that these would have to be high-quality tires, in either case.
That is not where I thought this discussion was going!!
I just looked at the Airstream brochure.
The Classic is not just one TT model. It is a whole line of models.
It is their very best, no compromises line.
It is interesting that not only do they SPECIFY LT tires for their top of the line TTs, but they SPECIFY what is considered by many to be the Gold standard.... Michelin® LT225/75R16 Tires.
That is what I run. IMO, they are the very best.
They are NOT cheap.
But compared the the "ahem", more affordable tires I used to run, they actually are cheaper over the long run. But it does hurt the wallet at replacement time.
Still, I won't ever run anything else. The punishment I have subjected them to would not be believed by the ST crowd... Yet they take it in stride. ZERO trouble of any kind in eleven years.
Yes I tow heavy and fast, in Arizona's high heat. Yes they have been curbed, hit pot holes and been driven over large sharp pointed rocks, been off roaded as a routine matter, and they just flat out work.
If they didn't, I would be making a change.
I will never again make excuses for a tires poor reliability. They need to do what I pay them for.
44,071 PostsLatest Activity: Aug 30, 2026
