billtex
Oct 22, 2013Explorer II
hmknightnc wrote:
I think you need to check your numbers again. Your 1/2 ton truck can't have a rear axle rating of only 3150, that number is too low. If CWR means Cargo Wieght Rating then that is the number the manufacture recommends you do not exceed and ~1500# for a half ton seems about right. The absolute maximum you can load is GAWR minus actual wieght on the axle prior to loading the camper.
2400# on a half ton is not going to work. 2400# will likely work on a modern 3/4 ton but might be too much even for an older 3/4 ton.
Actualy...that sounds about right for a 1/2 ton RAWR.
44,056 PostsLatest Activity: May 04, 2014
