fatboy66
Oct 14, 2014Explorer
kimberwarden wrote:
We have a 16' vintage trailer that weighs less than 2500 lbs. We pull it with a 2013 Toyota Prerunner (rear wheel drive) double cab V6. It doesn't have the factory tow package, just an after market hitch and electric brakes.
That setup should be all we need, right? But yet towing the trailer on the freeway feels unsafe. The back of the truck sags somewhat under the weight, and driving feels more like skating on ice. It doesn't feel like we have good control of the truck.
The trailer doesn't fishtail. Instead, it feels more like it rocks from side to side, shifting its weight from the left to the right tire and back again. It might not truly be doing that, but that's how it feels inside the truck.
We're new to trucks and towing, so maybe some of this is normal? Or does it sound like we need to inflate our rear tires (we don't currently add any extra air when we tow)? Or is a weight distribution system our likely solution? Or should we replace our shocks? If we don't get this figured out, our trailer hauling days are probably over because the idea of hitting the road fills us with dread instead of excitement.
Thanks so much for any advice you have to offer!
kimber
Honestly, it sounds like you need to inform yourself about basic towing principles. With the volumes of info out there, you owe it to yourself and your family to do your homework and learn how to safely/correctly tow a trailer.
44,071 PostsLatest Activity: Aug 16, 2026
