jfkmk
Oct 14, 2014Explorer II
I agree with the others regarding a wd hitch. Get one like an equalizer that has built in sway control. Also, it's a pretty light weight truck, so heavier duty shocks may be in order. You may want to add a trans cooler if the truck doesn't have the tow package. When towing, keep the speeds down. 55-60 is fine, you're not in a hurry, right? Keep the tires inflated to the max. You'll probably always feel some kind of sway, but it shouldn't be white knuckle.
44,071 PostsLatest Activity: Aug 16, 2026
