westend
Oct 14, 2014Explorer
Here is a link to a 16' 1964 Oasis that has a weight estimate of 3000 lbs. How did you estimate the weight as "under 2500 lbs" or did the salesman tell you that? You need to weigh the trailer and truck at a certified scale. Cat Scales are the largest network of truck scales and there is one probably within 25 mi. of your location. Be careful on the way to and from the scale, I believe your Toyota is overloaded.
44,071 PostsLatest Activity: Aug 16, 2026
