CavemanCharlie
Oct 17, 2014Explorer III
The trailer weighs 2500 pounds. If the Toyota can't handle that without a Weight Distribution Hitch I'd get rid of it. I wouldn't be the least bit afraid to tow that behind my 1984 Lincoln Mark VII car.
That being said, I agree take it to a scale and get a tongue weight. You may be loading the trailer wrong. As has been said, check the pressure and types of the tires. The right tires and the right pressures will make a big difference. And, I say again, if everything else checks out ok, then check for a bent axel. It happens quite often and if things are out of alignment it will tow like crap. Been there, done that.
44,071 PostsLatest Activity: Aug 16, 2026
