UTCoyote's avatar
UTCoyote
Why ST tires?
Hey All,
Total noob, trying to soak all this RV stuff in all at once. The Maxxis ST tires on my recently purchased 2001 TT "look" like new, but I don't know how old they actually are, so don't know how much life I should consider they really have in them. I need to research how to read the date code on them.
When I do buy new ones, I'm wondering why ST's? With their 65 MPH speed limit, there has to be some redeeming properties that make them desirable for TT/RV use?
Without knowing anything - which I don't - on the face of it, seems obvious to put LT's on. They can be had in load ratings plenty heavy enough and not be stuck in the slow lane with the semi's all the time.
- Coyote
  • Good info all around! I read the links and thanks to 2edgesword I can check the dates on my tires.
    After reading the links provided and the posts so far, I am leaning heavily towards LT tires when I need to buy new ones. Don't mind getting new wheels, bigger tires, as the axles are already flipped so plenty of room for bigger tires and a little bit more ground clearance from taller tires would be welcomed.
    And it's not so much that I'm going to be in that much of a hurry, just that a lot of the interstate around here is posted 80 MPH and the de facto speed limit is 85 MPH. Doing 65, a full 20 MPH less than everyone else on the road, even in the right lane, makes you kind of a hazzard to the other drivers. I'd like to be able to do 75 MPH and not have tires be a concern. Plus, like I said, for how I'll mostly be using the TT, a little more ground clearance would be nice. Plan on welding up some skid plate for the exposed drain pipes before taking it anywhere as is.
    - Coyote
  • One reason for using ST tires is the load rating for the tire size. While LT's would be nice, often it is impossible to find a LT tire in the size for the trailer that will carry the required load. For example, in 225/15" tires, LT's are hard/impossible to find above LRC, while ST's are available in LRE in the same size.
    Once you go to 16" rims then you can get LT's with LRE or higher so they make sense to consider.
  • In the beginning we used truck tires (LT) or passenger car tires (P) on our RVs. In the '70s American tire makers gave us the ST tire which was a compromise between the P and LT but more importantly as Goodyear said "the ST tires were economically priced". They were to be used on trailers only and not suitable for use on other vehicles.
    I've owned several different RV trailers and many different sizes of equipment trailers for my business. After taking possession of any trailer the first thing I always do is dump the ST tires and go with a LT. It may require changing wheels or modding the trailers suspension but for zero issues with tire in the long haul its worth it for me.
    I run LTs on my RVs for seven years average and in the 55k-60k mile range with zero issues at any speed I choose. My equipment trailers were on the road much more and have ran many a set up to the 70k range however those miles were in 18-24 months or so. That sold me on LT over and ST.
  • The date code will be in line with the DOT information and if the tires were manufactured after year 2000 will be four numbers with the first two representing the week of the year and the last two representing the year...
    2311 would be the 23rd week of 2011
    1002 would be the 10th week of 2002
