PointyWombat's avatar
PointyWombat
Wierd Marks Appearing On Tires
These vertical marks around the tire circumfrence stared to appear on the rear tires of my 2012 silverado 3500 SRW. I recently rotated my tires and front tires did not have these marks. Since rotating, the marks have started to appear after approx 3000 miles. I tow occationally a ~11k lb. fiver. I've towed several times since rotating.
The tires are Cooper Discoverer X/T4 with approximately 35000 miles.
https://imgur.com/gallery/8L5vgwE
Any thoughts on what these indicate would be appreciated.
Thanks,
PW
  • I think it might be a replacement indicator. With all of the sipping not sure but look like a winter or true 4 season tire. Winter tires and true 4 season tires with the mountain snowflake have a second set of wear indicators to show when there is not enough tread left to be safe in winter conditions.
    If you have the severe winter mountain snowflake on these tires I am pretty sure that is what this vertical line is.
  • I don't any thing but a the tire wearing more in the middle than the edges. Prolly from over inflation.
  • After enlarging the pic it does look like they are molded in. The groove does not cut through the edge of the tread blocks. If that is a wear indicator that is a new one for me. Interesting what it really is.
  • I have never seen a wear bar like that just the raised patches between tread blocks also shown in the pic. I looks like something is rubbing. Do they show on both sides?
  • Looks like a tire replacement indicator. On some tires they show up when they are nearing replacement. And from the looks of the tires they are due anyway.
