SoundGuy
Oct 20, 2016Explorer
ReferDog wrote:
Locked rotor amps=same as if it was seize-up for 1second generator won't handle it. Looked into a START CAPAITOR ON THE A/C compressor this helps reduce the starting load.
Successfully starting any A/C compressor is all about LRA ... anyone who bothers to check out the Micro-Air Easy Start Soft Starter which I linked to above should easily understand why this A/C compressor start accessory which reduces start up current by 65 - 75% is far superior to just simply adding a hard start cap. :R
44,056 PostsLatest Activity: May 04, 2014
