jimh406
Mar 23, 2016Explorer III
If you heat it, it will probably come off easily as the adhesive on most tape is heat sensitive. You should look at the instructions for the particular tape you want to use though. BTW, it also means that if it gets hot, it might release unexpectedly.
44,068 PostsLatest Activity: Jun 21, 2026
