sdclaw21's avatar
sdclaw21
Will I kill my mini-van?
I currently have a 13 Chrysler T&C with an aftermarket class III and a 4 flat harness. I’ve used it to tow an 8ft utility trailer to the dump and occasionally a 1500lb pop up camping. I have an opportunity to purchase a small hybrid camper from a family friend at a good price. It’s dry weight is +-2950 with a tongue weight of around 350lbs. The vehicle comes standard with a trans cooler and has a max towing rating of 3,600lbs. Remaining relevant info follows.
Vehicle curb weight 4,600. GVWR 6,000. Combined GVWR 8,750. Tongue Weight 360. Family weight w kids and a dog 550lbs.
With the understanding that we will have to travel bare bones light with empty tanks on the trailer is there a reason this set up won’t work? Including bikes, a set of golf clubs, a suitcase for each, fishing gear, essential dish ware and bedding along w and groceries I can’t imagine we have more than 400 pounds of gear. I would be upgrading the rear shocks and installing a brake controller in the van. Trips would be within 150 miles and would be through mostly flat midwestern terrain.
  • Sounds like you're committed to this already, and just asking for validation at this point?
    Can you switch from P to LT tires on the van? That's what wore the fastest when I was towing with a station wagon. P tires did not like towing at all.
    That tongue weight is too low. Did you measure that, or just get it online somewhere?
    Any trailer that heavy will have its own brakes, you should upgrade to the 7-way bargman connector and suitable brake controller on the van.
