westend
Mar 27, 2014Explorer
Ruthless wrote:Anything in the plumbing system is designed to hold a certain pressure. Nothing is designed to fail quicker or slower from freezing than another piece of the system.Weldon wrote:
On some of the trailers is it true the fittings are designed to rupture before the water line? The fittings on the outside shower, split twice on my fifth wheel. That small plastic cover does not offer much protection from the cold.
How cold did it get for the fittings on the outside shower to freeze and rupture? Shouldn't I be able to tell if that has happened by a visual inspection?
Since I live in MN, and have a few years and freezing events under my belt, this is all just pretty much common sense. If you leave water in a pipe and there is no room for expansion and water is left to freeze in the pipe, it will expand and may rupture the pipe. The same holds true for fittings like 90's couplers, tees, etc.
PEX pipe is pretty forgiving about freezing and a light freeze or temporary cold night like someone may get in the Southeast, wouldn't be cause for alarm. I would think that if the system is drained, all will be good if it's just a temporary temperature dip.
If the OP is still teeth-gnashing about the possibility of a leak, pressurizing the system with air and observation will probably turn up any freeze problems, and straight away. Knowing how cold someone else's trailer endured is not going to be too relevant. I would put 50 psi of air into the system and see if it holds fairly well. Observe for the hiss or flow of air. After that, fill with liquid (antifreeze may be a good choice) and pressurize the system. Observe for leaks.
44,056 PostsLatest Activity: Nov 19, 2013
