srockey wrote:
I am looking for a new/used truck to pull my travel trailer. I have a Keystone Passport Ml199 that weights 3800 lbs empty. I would like to get decent gas mileage since it will be an every day driver. The truck I am looking at is a 2014 Chevy Silverado LT Double Cab 4x2, 6 cylinder. The specs sheet says 6,000 to 7,100 lbs, and I know those are over estimated. What do you think?
Thank you,
Steve
Hey Steve - in my opinion, the truck you are looking at would most likely be fine with the TT you mentioned. However, not mentioned here is the fact the the engine will have to overcome the sail effect that a high walled TT creates when going down the road. Gas engines make their power at high RPM's so it will be working - notice I didn't say struggling. Hilly mountainous terrain will be challenging too.
I towed a slightly larger TT with a 2003 Tundra - had an 8cyl 4.7 engine. It did OK - barley OK. I didn't like it - felt like I was driving a waterbed, even with the correct tires and upgraded shocks.
Here are the comparisons between these two which seem to give the V6 for the truck you are considering an edge over my Tundra:
4.7L Gas V8 Horsepower 240 @ 4800 RPM
4.3L V-6 V6 Horsepower 285 @ 5300 RPM
Note though that the V6 will be revving higher. According to a few Google searches on your stated truck/year, EPA fuel economy estimates stand at 20 mpg combined (18 city/24 highway) for two-wheel drive. With the 5.3-liter V8, the same model/year will achieve 19 mpg combined (16 city/23 highway).
If your preference is gas mileage over towing agility, get the V6, but if, thinking ahead, you think you may want something bigger, then opt for the V8.
I didn't look at the numbers for later model 5.7 liter Tundras, but they are very capable tow vehicles and give other brands a run for the money quality wise. My 2003 had 160K miles on it when I sold it, and I still see it running around my area.
Whatever truck you buy, don't buy based on the manufacturers tow capacity number. Research payload. Make sure you have Good LT tires - not P rated passenger tires, and is should also have a tow package.
Good luck!
