JIMNLIN
Mar 14, 2018Explorer III
Looked up his Vengeance Rogue 38' 5th wheel toy hauler 10258 dry weight.... FR website shows a 4000 CCC with a 14257 GVWR.
His 2017 2500 GM 6.6 diesel LTZ 4x4 long bed 18" wheels shows a 12400 lb 5th wheel tow rating for the crew cab or a 15700 lb tow rating for a double cab.
Seems like a lot of difference between the CC a double cab...
GM weights calculator shows his truck has a 3178 lb payload on the rear axle.
Same truck as the 3500 SRW so everything on the truck is up to the job and more however the 2500 trucks rear suspension will most likely need air bags or some type of help for the spring pack. your call.
