AKSuperDually wrote:
artguys wrote:
Buy a Post/Bottle jack...minimum 12 ton. I carry a 20 ton...the larger the easier it is to jack. And always carry along small block of wood to place under any kind of jack.
I also carry a 20 ton bottle jack with me. Often, I take a farm jack as well...works awesome for trailers and multiple other uses.
I too use a Bottle Jack, for a couple of reasons. First my F550 is really heavy and I don’t want to trust the Factory Jack or take the time to get it from behind the back seat and assemble it. Going with that theme, I don’t want to take the time to lift the Camper off, making sure it is supported on gravel shoulders and level so it won’t shift, while it is up. Who can figure whether you are going to have a flat on a windy day?
The other important point, is you have dually as I do, so you already have a jack ready to use, for some of the tires. If you were to get a flat on the outside duallys, just get a few of your ramps and drive the tire that is “not” flat up on the ramp/s to get it high enough to remove and install the spare. Then drive off of it, put them away, as well as the flat and you are good to go. (Sadly, all my back tire flats have always been the inside dually. You can start feeling the tire going flat as you will start feeling a vibration.
One small tool that is really handy to have is a; Stanley Wonder Bar (Home Depot/Lowes). One of the problems, for those of us with the 19.5” tires especially, is getting the Spare tire up and centered enough to get on the Wheel Studs. Take the Wonder Bar, put it vertical next to the tire, with the short bend under the spare tire to the depth of the small bend end. Then pull down on the long end and it will lift the tire up to any height you need. Also, if the holes in the rim don’t line up perfectly with the studs, while the tire is lifted off the ground, turn the Wonder Bar left or right, as needed, and it will rotate the tire clockwise or counterclockwise. Handy tool, just like the Bottle Jack is. For me, I just open the door, there is the bottle back front and center in the storage cabinet, as well as the Wonder Bar and I have written the socket size for both the truck and trailer on the inside door so I don’t need to fumble to find which ones work.(No doubt you know a lot of this, but others following this thread might find it helpful.)
Have fun, Truck Camping is a grin!
b
