tooldad1041's avatar
tooldad1041
Wind deflector between cabover and cab
Anyone tried making a V shaped wind deflector between the cabover and the top of the truck?
I have some 1/2" rubber left over from making my snow plow flap, I think that with aluminum angle iron mounted in a V shape might help deflect some air from going between the cab and cabover and just swirling around.
Big rigs have basically the same stuff at the bottom or their fairings on the sides, helps with air flow, should do the same on a TC.
will be measuring and cutting monday. Tuesday I am headed to IN/MI to have new top put on at Palomino factory, then off to Buffalo NY to visit a friend. We will see if it makes a difference.
Any thoughts on if this will work or if I shouldn't waste my time?
  • Art Schlangen wrote:
    Try this one. ART
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27017146/srt/pa/pging/1/page/1
    I just read your post... do the Tabs work, you haven't said yet, have you put many miles on them?. They have been around for a long time... I have never read any reports from Truck camper owners... I would want to know of other truck camper owners successful experiences over time before I spent that kind of money.
    I looked at the Air Tabs a long time ago... they were quite expensive at that time... and they appeared to me to creat turbulance... I wanted a laminaire (smooth) air flow. Turbulance creats drag, any drag hurts fuel economy.
    Like many before me I decided to try to build my own solution:
    I had some wind tunnel experince to help me understand my decisions and tried a solid deflector... it moved the wind away from the area between the TC and the truck's cab but created another unexpected problem... it created a negative pressure area behind the air deflector... dirt and rain water from the road surface was pulled up between the back of the trucks cab and the front of the trucks bed.... it was dirt, oil, water mixed in to a nasty mess... I prefered the bugs and noise that I'd eliminated.
    I decided to drill some holes in the solid wind deflectors in order to equalize the air pressure behind the wind deflector...eliminating the the road dirt problem.
    I like PVC... easy to work with, light weight, easy to repair or make changes... while looking for more "pvc siding" to use for prototype deflectors I ran across the 5' sections of gutter gard... the holes were already there.
    It turns out that the "gutter gard" works much like a macro membrane... the balance between air pushing on the front ao the Airfoil and the small amout that slips through is just about ideal.
    How can I tell how well it works... bugs slide out to the side of the camper in the slip stream... none on the bulk head. No noise. And, no more road dirt sucked up into the bulk head area between the TC and the truck.
    I wouldn't recommend my Airfoil except that there have been many built and happily used... for the last 10 years. (I'm still using the original prototype)
    The cost... less than $20 total... and a bonus, the fact that most truck camper owners seem to be creative, hands on, even skilled people that like to think things through, to understand, and to find the best solutions.
    I have built more than 30 of my Airfoils for others as they stop by the house... and cheered on or coached hundreds more as they built their own... by pm, email, and phone. (This was the 4th request this week)
    Good luck to everyone that builds an Airfoil... and I hope the Air Tabs work out for Art.
    Sleepy
  • Try this one. ART
  • When you look at the Airfoil link the first pictures are for a single or extended cab... for a crew cab you won't need the cross bracing.
    and theforward are wpold be about 22" accross and then the side sweep back about 18"
    Use existing screew holes
  • In answer to your email:
    Evidentally you have created a wind deflector between the cabover and the cab on your truck camper? If this is true, sorry i can't find any links describing it, could you please pass along any suggestions or advice, as I would like to add it Monday and Tuesday before heading from St louis to Buffalo NY.
    thanks!
    tooldad1041
    Sent: 06/21/13 04:06am
    Subject: RE: wind deflector for truck camper
    Here it is... the name keeps changing and the location.... it would help if the first word was Airfoil.
    To get the 5' long guttergard I suggest that you might get it here Sometimes the big box stores will have the 5' sections of maybe the 3' ones. Get a couple of extras. (you can glue them together by overlaping and lining up the holes.
    get Clear PVC glue from someone that has a lot of sales... it has a 6 month shelf life
    And the PVC white siding "F" channel from a big box store 10' section
    I use double stick weather tape betweeen the camper and the F strip
    the big box stores have small metal spring clips (clothes pins) for about 39 cents a piece... get a handful... they are handy for this project and for your potato chips in the camper when your finished.
    I hope that you have time to get your parts together... pm me for a phone number if you need.
    By the way... the holes are essential... they break up the low pressure area behind the airfoil. If you have a low pressure area behind a fairing it will suck road dirt up between the truck cab and the trucks bed.... nasty...
    With the Airfoil... you'll know you have it right when there are no more bugs on the bulkhead... and your fuel economy goes up.
    good luck
    sleepy
  • guess I missed it and having trouble locating thread. if you can, please give a link
